Crank case vent mod done
- Replies 8
- Views 2.4k
Mopar1973Man 3 posts
Doubletrouble 3 posts
Dieselfuture 1 post
gerlbaum 1 post
Popular Days
Looks good. The design I see you tweaked it a bit for the front two elbows I like the way it turned out.
Been meaning to get to this mod for a while. My radiator is getting covered in oil and dust sticking to it so it was time. I followed @Mopar1973Man's write up on this for the most part. I did reuse the hose from the oem vent. I cut off the "J" part of it and used the piece that kind of jogs over a bit. It's a tight fit getting the pvc in it but it works.
To paint the pvc I used rustoleum satin black implement/industrial paint. Dries to the touch in about 15 minutes and seems to cover and stick to the pvc pretty well.
Thought I'd share a couple pics.
