- Replies 8
- Views 2.6k
Mopar1973Man 5 posts
jag 1 post
Me78569 1 post
Threadzy 1 post
Popular Days
You would have to change the timing slightly maybe? Being pop pressure is low and timing is more advance than stock 310 bar. Rest of it should work good. Just for info this is the 3rd time
Same tank now at 400 miles at half tank. I'm in Caldwell ID. I've got enough fuel even to drive back home. Yeah I've got the tune dialed in.
Need to get your 65 MPH up around 2k RPM to catch me. Like 245/70 R17 would match me ratio wise.
Could someone advise me on what the default parameters settings are for the Quad, & who set the defaults perimeters?
Thanks
