Low power highway speeds
- Replies 8
- Views 2.3k
Mopar1973Man 3 posts
BennyGGG 3 posts
Dieselfuture 1 post
Silverwolf2691 1 post
22 psi seems awfully high at 1800 rpm with only 30% throttle.. Vacuum doesn't matter as much on a diesel.. Intake MAP is 36.83 psia, so minus 14.7 for 22.13 psig.. 0.2 psi is e
Boost fooler may be not functioning or map sensor going waky
Standard math can't be used to correct map values for boost. I've tired many time but does hold any accuracy. Best to have a boost gauge.
I have the preface this post with: great community here with an insane wealth of knowledge and skill. This forum has been a time and money saver numerous times. All contributors are much appreciated.
I encountered an interesting problem on the way home from work today. I had very little “guts” at highway speeds. I normally set cruise control around 70 and have plenty of power to accelerate up to 80+ without hesitation. Today I basically had to floor it and it felt like someone sapped the power right out of her.
When I got home I poked around the engine bay a bit. Made sure I had good vacuum connections. Nothing out of the ordinary.
I took her back out with my wifi ODB monitor hooked up. The truck was right back to Normal. No issues at all. Plenty of power. Screenshots attached.
what do you guys think? What should I be looking for if this issue comes back? Thoughts?
I have a full suite of gauges coming in this week. Fuel pressure, EGT, trans temp and boost. Hopefully if it happens again I can have more info to pass along.
2001 2500 4x4 47re leveled on 34s. Engine/drivetrain is stock except for an edge EZ.
