more abs brake problems
- Replies 10
- Views 2.7k
01cummins4ever 4 posts
Mopar1973Man 2 posts
Evan 2 posts
LorenS 1 post
I’ve just about on information overload In searching out this abs brake issue and trying not to parts change components until I find the problem, I do have rear brake abs along with rear drums, abs and brake light come on only after first full application of brakes and will stay on along with the spongy and week brakes, system will reset itself when I turn key off and then the cycle starts again the first time brakes are applied, they act like air in the system and it seems like I can gain a little by pumping but not much. I have not tried bleeding at the wheel because it seems if it’s leaking internally it wouldn’t do any good, It does not leak any fluid. The speedo works as it should and cruise control will not work or even illuminate on dash, I have not taken to dealer yet for codes but wondering if they can pin point a bad master cylinder or that thingy thing ( I forgot the propper name for that) aft. the master cylinder or any other parts in the system
