- Replies 9
- Views 1.7k
Dieselfuture 3 posts
Andyba20 3 posts
Mopar1973Man 1 post
IBMobile 1 post
You can only get the seal with a new cap. Dodge # 05014704AB Stant #10111 Gates #31118
Any part store carries the replacement oil cap. I've got a start oil cap and it does not have the ratchet cap.
3936876 is the only part I saw even close to this and came in oil filler tube kits for 12v’s and C series engines. Thickness of construction paper.
Does anybody know the part number or correct size for the seal/gasket that sits on the valve cover around the oil filler hole. Took my oil cap off earlier and the gasket disintegrated.
