- Replies 39
- Views 7k
2000Cumminsyessir 15 posts
Mopar1973Man 12 posts
Doubletrouble 5 posts
JAG1 4 posts
You should cancel the order if not a Timbo. They are superior and half the cost.
Very true...
I checked the codes and nothing comes up on my code reader. No codes with the key trick either. What's weird is I already replaced the injectors with oem that's what I thought that initial issue was.
Hi guys, first post! I have a 2000 Ram 2500 5 speed. Runs great for the first 5 minutes in the mornings then she's having what I would say a miss at idle and rpm Fluctuating between 800 to 1000rpm. Once I hit the throttle the rpms stay at about 1100 and will not come down until it's in gear. Also when I drive it, and coming to a stop, the idle is high and makes it harder to stop. I had a map sensor code and got that cleared. I changed injectors (oem) thinking that was the issue but nope still there and does the same thing.
I did replace crank & cam sensors. (I was playing the guessing game) I did notice when unplugging the cam sensor that no check engine light comes on and it runs the same with it plugged or unplugged and I believe all sensors should have 5 volts, which they all do. I had alternator tested for diode issues and it was fine. I replaced batteries about 2 weeks ago.
I checked Apps sensor this morning and its reading 0.31v. There is no sticker on it to know what the voltage should be at. Would app sensor be the issue here or what?
Thanks for all your help!
