- Replies 28
- Views 5.2k
Mopar1973Man 9 posts
wil440 7 posts
IBMobile 3 posts
Andyba20 3 posts
Not hard to find. Gates Part #350390 or https://www.oreillyauto.com/shop/b/chassis---steering/power-steering/steering-seal-kit---pump/6d9b69569080/v/a/1985/automotive-truck-2000-dodge-ram-25
Hydroboost more or less is just the same as the vacuum booster on a gas vehicle. All it does is adds force to your pedal effort. The hydroboost and brake master are completely separate systems still.
First thing is to flush the system before pulling the old pump off. Make sure to get all the dark fluid out or any metal particles out. Then you can install the new pump. As for flushing a
Came outside a few days ago and there was a 1/2 quart of ps fluid on the driveway (truck was idling). Ordered a brand new pump with reservoir from Napa and having a guy install it this week. Did I read something on here one time about a vacuum pump seal having to be replaced along with replacing the PS pump? Also, can’t say I fully I fully understand the hydroboost system, are there any considerations my mechanic should know while he’s doing this job? I’ll be keeping the old pump as a backup and rebuilding with a seal kit, just didn’t have time to fool with it right now so bought a new one. Any tips I can pass along to this old guy would be appreciated. Goal is to get another 300K from this new pump.
