Huge difference in fuel psi.
- Replies 7
- Views 2.3k
Mopar1973Man 3 posts
Sycostang67 2 posts
wil440 1 post
Doubletrouble 1 post
Ok, I got the Adrenaline fuel pressure sensor installed last weekend and now my readings match. I guess the sensors are internally different.
I'm trying to figure out if the sensor Edge uses is different from the one Quadzilla uses. Some of the vendor pics aren't the greatest but they do appear to be a bit different physically at least. I
I have a GS fuel psi gauge I have been using since I installed my FASS pump 7 years ago. Since I installed the FASS it has always hovered around 14-15psi with the sensor mounted on the pump. When I got my Edge tuner I added a second sensor in the line 12" before the VP44 and it also hovered around the same level. When I got the quad, I used the same sensor I was using with the Edge as it plugged right in. A few days ago my GS gauge began reading 0psi, I pulled up the Quad fuel reading for the first time and noticed it was around 25psi which I thought was odd but figured I had pressure so I'm good. While trying to figure out the GS gauge issue I noticed my FASS wouldn't prime with a key bump. I start the truck and pull the fuse for the FASS and no change in pressure from the Quad. I unplug the relay and plug it back in and now my GS gauge is back to 15psi but the Quad is now reading 50-60psi. Through all of this the truck has run normal, starting fine, running fine, no sign of fuel starvation. I remember a few years ago the fuse for my FASS blew and I could barely get out of my driveway.
Edited by Sycostang67
