- Replies 67
- Views 9k
Andyba20 24 posts
Mopar1973Man 14 posts
IBMobile 6 posts
wil440 6 posts
This is how @Mopar1973Mankeeps his final drive ratio low. He turns his 245/75R16 tires into 245/70R16 tires by letting the smoke out. - John
Try this, remove the hose from the wastegate actuator, block off the hose, and take the truck out and do a few hard launches. You should see 28-30PSI. If still low boost, then waste gate problem, if
With all that "coke" deposit at the waste gate opening, don't know how good of a seal it had.
Just trying to track down the issue efficiently, if anybody has a good/better/best place to start. Did a boost leak test last week, found a few leaks, tightened some clamps, leaks gone. Threaded in a new boost elbow. Before, with leaks, I was seeing about 18-19psi max. Now I can’t get to 10psi. Set screw is turned all the way in. Bleed orifice does seem to be constantly bleeding air, but I’m not sure if that’s by design or not. It’s the adjustable boost elbow from DAP.
