Head studs, valve springs, what else?
- Replies 38
- Views 5.9k
Spdfrk 16 posts
Silverwolf2691 11 posts
Mopar1973Man 9 posts
Threadzy 1 post
It would be a hot 500, but a 62/65/12 can get you there too. Up to you and what you want. Also, @dieselautopower is a regular on the site and he can guide you to the right setup.
Well that came from the fact I had 5 years of running from New Meadows, ID to Ontario, OR with my mother @MoparMomto dialysis. That worked out to about 1,100 miles per week I drove. Total of 250k mile
62/65/12 is going to run hot at WOT. You will want more turbine flow... go with a 62/65/14 or a little bigger at 62/68/12. The 62/68/12SXE flows 77lbs/minute and the non- sxe 62/65 typically is 72lb
It's time to add head studs and I know I'm getting new, stronger valve springs as well. Is there anything else you all would recommend doing at this time as well??
