- Replies 28
- Views 3.6k
wil440 10 posts
Mopar1973Man 6 posts
LorenS 6 posts
Silverwolf2691 4 posts
I read the tuning guide and watched the vid this morning, needless to say I now have a "test" tune to see what it runs like against my tow tune which is what my truck is always on. I've dr
I took the truck for a quick test this morning, seems to run ok, boost way higher than what it is on my tow tune. 20ish on tow tune to over 30 max on this test tune, run not long enough to spend much
My truck on longer journeys usually has my trailer hooked up and I lock out OD, everything has been fine also I tend to lockout OD around here also as it means the convertor is locked for much longer so revs down and MPG up, it can trundle along just over our lowest built up area speed limit of 30 just nice, pretty flat here.
Yesterday I went to fit a turbo boost sensor on a Volvo loading shovel, already visited to diagnose and was 100% sure so no need for my trailer just the part and a 8mm ratchet spanner and a small screwdriver
Noticed the change from 3rd to 4th was harsh and not what it usually is bearing in mind It may not have done that upshift for a bit, last time I recall was towing on the motorway downhill so throttle backed off anyway, I turn on OD in this situation then off as soon as the downhill is done when towing.
Checked for codes this morning and there was only battery voltage low, this was from when my alternator resettable breaker popped the other week while jump starting a Peugeot Boxer, I did disconnect the quad before the jumpstart,.
I cleared the low volt code and ran the truck, no active or stored codes in Engine ECU ,PCM , ABS or Body.... nothing and this is with a SO Modis at 2018 software so there is no codes.
The truck runs and shifts ok other than hard into OD, trans temps yesterday at 50 miles round trip was around 120f give or take
My next thing is to turn the quad down from 9 to 6 and see what that does, this could well be the cause thinking about it
Other than that I may have to drop the pan any other suggestions ????
