Speed Round-General Questions
- Replies 21
- Views 4.5k
Mopar1973Man 6 posts
Andyba20 5 posts
Doubletrouble 4 posts
LorenS 2 posts
Shouldn't have to for standard little things like lights and small accessories. Large accessories like a winch should be wired directly to the battery. Yes, you can ONLY if the alternat
I know I'm a bit late on this, been a busy week. Here are my reverse lights. I have LED bulbs in the stock sockets and the the LED light strip with brake/turn signals and reverse lights. Makes for ple
Yes there should be teeth showing. If not you not going to be able to slip a pitman arm puller up there to get the pitman arm off. So what you'll have to do is unscrew the sector adjustment and beat t
What’s going on here? First question, steering gear/ pitman arm. Should the teeth be showing? I’m guessing not. It’s torqued to 185f/lb.
