- Replies 5
- Views 3.4k
Mopar1973Man 1 post
Me78569 1 post
LorenS 1 post
Silver_O1_Dually 1 post
Popular Days
HO pumps have a more aggressive ramp up of fueling via the pump ring, but the ho also has smaller diameter plungers causing total fuel per stroke to be less than a SO pump. Generally peo
No. Don't bother with a hot rod pump. Only roughly 20 HP gain. Makes a problem for tuning being the hot rod pump mechanically advanced internally. Better of with stock SO pump
The Bosch part numbers for the SO vs. HO injectors are different, but I do not know if there are differences in pop pressure, nozzle spray setup, etc. Don't the HO units ramp up injection
It’s time to replace the VP44 on my 01 HO 6 speed. I’ve been doing a lot of research on different pumps and suppliers.
I’m taking the advice of Mopar Man and have decided to go with a DAP remanded pump.
my question is are the “Hot Rod” pumps worth the extra coin?
I will be upgrading my injections to 7x.010’s from DAP at the same time.
I do not have any tuners on the truck.
