So, I got my DAP 150's in and there seems to be yet another issue. Truck sat for a few weeks and then I got to doing the injectors and changed the oil and filter (had a lot of fuel in the oil). Put 3 gallons in, got the truck started (checked oil level before, was above operating range) and truck drove and ran great with the new injectors. Was getting about 60-70 PSI cold and once she was warm she was at about 40, but then she went to about 35-38 while cruising at 60. At the stop light, It was right above the lower limit line on the dash gauge. Got to my destination ASAP and shut her down. Looked for major leaks or anything and didn't see anything going on. I went and ate and then came back after an hour and checked oil level and it seemed to be below the point on the dip stick... I'm planning to get a mechanical gauge and fill it up til I'm in operating range and then start it up, get it warm, etc and monitor it. One of my friend's believes that it sitting for a few weeks drained the head, galleys, etc and I got more oil out than usual and then put the 3 gallons in. I also spilled some off the head because I put the new oil in with the VC off and didn't realize some was going over the edge I don't believe I let 2+ quarts go over though. I'm afraid maybe running a few miles with fuel in the oil ruined my bearings or maybe ruined the seal on the turbo. Planning to check for oil in the downpipe here too.
If any clarification is needed after this ramble, please don't hesitate to ask!
Just take a little time..... If you have the same oil grade that is in it now just take a feel between whats in it and whats in the still new jug/drum/whatever at the same temp and see what the diffe
Hey all, back again! lol
Thank you,
Dylan
