Ok time to upgrade the turbo
- Replies 9
- Views 8.9k
Silverwolf2691 2 posts
Stanley 2 posts
tucothelegend 2 posts
LorenS 1 post
Popular Days
k27 or s300g would probably be best if you are gonna stay at this power level. s362/65/12 would be the next step up if you were going bigger for injectors. HX35/40 hybrid would
Are you running an oiled filter like a k&n? Generally, oil on this side if the wheel is from an oiled filter. Bad oil seals you wouldnt see unless you pulled off the intercooler pipe.
The base info: 1999 ram 2500 stock turbo 5.9 Cummins. 75 hp injectors, new vp 44, fass pump Quadzilla adrenalin
I took off the intake box I found oil around the cold air vane inside the turbo
so the questions are should i buy a replacement stock turbo.
or should I get an up graded replacement a little bigger turbo
what size would work in this configuration
