- Replies 23
- Views 4.6k
Mopar1973Man 8 posts
Me78569 4 posts
Hutch24v 4 posts
Andyba20 3 posts
you will have a very solid 350-400hp towing setup if you use the quad to tune your canbus lvl 3 tuning and don't use wiretap levels. Thats a good way to go about it, the sxe is a good turbo. If I wa
Use a GPS to track mileage. Error correction math never works. Better yet to have the ABS corrected for proper speed and odometer.
You can be under 450 by just not using wiretap levels. In my mind it will be a nice setup with the 62. A 57 would be better, but I wouldn't be having buyers remorse.
Alright so after getting all my boost leaks fixed, I was finally able to install the ARP studs, and remove the Smarty tune. I’ll be installing the Adrenaline this week, as well as a set of Infinite Performance 7x.010’s. The goal was to have a reliable tow rig at around 325-350 HP, but a forum member lives down the road from me and is offering a really good deal on a 62/68/12 SXE. So I’m considering doing that and making my hp goal 400hp. Will this tuner/injector/turbo combo give a good reliable towing experience? Is that turbo gonna be slightly too big? Should I wait and get a 57/65/12? Don’t want a lot of smoke, don’t want 600hp…just a solid reliable 350-400hp for dd and towing.
