Turbo/Injector balance for towing/EGT control
- Replies 53
- Views 11.7k
Hutch24v 17 posts
Mopar1973Man 11 posts
Me78569 6 posts
LorenS 4 posts
Good info. I've got a few things to install on the truck including the ATS 3000 and a new manifold so why not just keep going with some new injectors while I'm at it!
I think it is unrealistic to not gear down loaded down that much going over a pass. RPM's keep egt's down when towing. the 5.9 makes peak torque above 1800 rpm up to ~2200-2400 rpm. anything be
I’m running a hybrid I pieced together. Between that my injectors and a Quad it lights fast and tows like a mofo!
Hey All - new paying member to the forum. Taking a break from the CF for a bit. Question is all too familiar I suspect. Trying to decide what to do with my 2nd gen to optimize my setup. I'm towing - or should say carrying a new truck camper (~2800 lbs) and lately going through the Washington state mountain passes and ridgelines. Lots of long slopes. My signature shows my mods but mainly I want to see if I'd be better served by increasing my injector size from 50HP to 100 to better pair with the Fleece HX35 63/65 turbo i'm running. I do see a bunch of lag even with the Quad tow tune I'm running that i had the guys @ DAP build for me. I control EGTs on long inclines mainly with my foot and disabling O/D when its start to climb above 1250 F. I also have a new uninstalled ATS Aurora 3000 turbo on hand i've been thinking of installing as its sized for fast spool up with a 58 mm inducer and for towing applications. Thinking that this maybe a better choice of a towing turbo with 100 HP injectors. I don't need any more power than 450 HP which is the power limit my 47re was rebuilt for. Hopefully this is enough to help some folks weigh in. Cheers!
