- Replies 9
- Views 6.5k
Mopar1973Man 4 posts
Doubletrouble 3 posts
AH64ID 1 post
JAG1 1 post
Yeah not to bad. Just got to dive in and fix the issues one at a time. At least it got cooling fans for now. Like the axle stub that isn't too bad. Smaller version of the truck axle. What
I've seen all kinds of Redneck fixes and they all suck. Not that it can't be fixed but why do half work? If you damage the yoke then replace it. Like my last screw up i was changing the rear most u-j
Those older ones with the inline 6 were tough little things.
Well I had a run to head up and look at @Honey Badger Mom's Jeep nothing really wrong just battery is weak security system tripping. Then locking out the ignition. Just unlock the drivers door with the key and its disarmed again as long as you dont leave the key in the vehicle. There was a family member that told her the catalytic converter was bad, nope there is a hole in the pipe near the catalytic converter. Misinformed and lead to believe big money repairs.
We took a break and ran with @Honey Badger jeep out Red Ridge to pick some mushrooms. Her jeep started to heat up. Fan weren't working. Her past boyfriend hacked up the entire fan circuit to make a wiring nightmare. Did a few modification on the dirt road and presto had at least key on fans.
Drove back to her place.
Now I parked right next to Thor and started working. Test light chr king fuses, found the factory fan plug. Tested got signal. Now I know I need a new pigtail. In the meantime to keep it going added a ring terminal for the ground to negative post. +12V I tucked in on the fan relay on the 87 pin. Fired it up and let idle it would get to the 210°F mark and kick the fan on drop to right about 200°F and shut off. Perfect.
Found a power steering hose bleeding through the jacket of the hose slowly.
She mention some welding on axle. Found it someone changed the wheel joint and crushed the outer stub some so the clip would fit so they welded the bearing caps in. Now ive got to pull that axle out cut the turnion out and discard the outer stub and replace the wheel joint.
Rear shocks are toast.
Really she has been misinformed about the amount of work and repairs like needing a whole new front differential.
