Oil Pan Gasket Replacement Advice Request
- Replies 18
- Views 5.6k
Mopar1973Man 7 posts
LorenS 5 posts
wil440 4 posts
Max Tune 1 post
Ha ******... Yes you can remove the pan without pullin the trans. Just drop the front axle so it hangs, the lift the engine 3 inches. Pull the pick up tube. Out it comes.
I'll be doing a pan gasket on this truck in my shop. I'm not going to video record this be time is tight. I'm going to unbolt the mounts and lift the engine a few inches to gain space. I did like I no
. Lifted the engine just enough so I can scrape off the old gasket. Both engine mounts are 22mm. It's going to be fun to slip the gasket in.
After mentioning last week that my truck leaks like a sieve, that bugged me all weekend to the point I want to get it handled before "someday", but have some questions.
I plan to change the front crank seal when I have the front half of the truck basically disassembled to put in new A/C condenser, straighten the mounting tabs on my intercooler (PO deer damage), etc. All this work will get done at my dad's garage and coordinating with his schedule isn't easy. I can change the oil pan gasket either in my driveway or at work.
