- Replies 38
- Views 4.9k
Caleb Hardy 18 posts
Mopar1973Man 6 posts
Threadzy 6 posts
LorenS 3 posts
The reason I went 4.10’s is there is a large difference between dodge transmission ratios and Allison. 4.10’s and tires that small get me closest to the optimal RPM range. If I had the choice 4.39 gea
No PC should be used technically for tunes. Yeah you can download it but the file is unusable on a PC. Then you should be able to use a ISB cable to transfer to your mobile device. At least for my And
I’m in Bakersfield (when I’m home hahaha) my email address is calebhardywelding@me.com This usually works for me.
I have been trying to chase down what would be causing my high egts. At first I bought into my turbo was not the right size, the tuning on quadzilla could off, and bit the bullet after all that and got rpms in the range they “should be” with no luck still. So I watched a video of MM and noticed the engine load was 17-19% while driving 65mph. My engine load at idle in neutral or park is 20-22%. In drive not moving 26%. Driving at 65mph on flat ground little to no wind 25-30% engine load=warmer egt’s. Now if I’m going slightly down hill and my engine load is 23% or lower my egts mimic the egts in the video I watched. I have a few questions. What are some possible causes of high engine? What kind of engine load are others seeing at idle and cruising? (Automatics) How does your engine load reflect your egts? Thank you ahead of time for all your input.
