- Replies 16
- Views 1.9k
Hutch24v 8 posts
Me78569 5 posts
JAG1 1 post
Tractorman 1 post
Snap On diagnostics screen can show a dead spot. Had this happen when cold just like you and when it showed, we changed out to the Timbo APPS right then no more problems until year later when the VP g
My truck is also an '02. The original VP44 set the P0216 code at 64,000 miles. Drove it that way for another year (learned how to get around the limp mode). VP44 replacement and lift pump relocatio
Noticed this condition a few times lately and its got me puzzled. Truck is experiencing a slight hesitation with acceleration when the truck is cold and not up to full operating temp. Almost like it’s a dead pedal for a split second at low rpms. Doesn't happen all the time and never after it’s warm. Scanned for codes and there wasn't any. Fuel pressure is good. (15-18 PSI). Low mileage truck (94K). VP44 is factory original. Wondered if it was Quad related, maybe the warm up mode feature I have enabled kicking in the power but it’s not. Any thoughts?
