I believe my fuel return line is leaking.
- Replies 12
- Views 2.8k
Doubletrouble 6 posts
Mopar1973Man 4 posts
Silverwolf2691 1 post
Threadzy 1 post
Did that one. You have to hug the engine with your head resting on the cowl.. Have a photo of me doing that somewhere.. Best to remove the hook point for a hoist as well. edit: found it. M
I will also do one on their site as well for that specific part.
The ol' Cummins bear hug to change the return line seals. Yes removing the valve cover works just a we bit better being you will have a bit more room to reach down with big paws. Sad to say I've got b
I'm talking about the line on the rear of the cylinder head. I was under there fir something else yesterday and noticed it's wet on the back of the engine and down the bell housing. A small drip was handing on the bottom of the bell housing. It was fuel. Could see the light green color.
I took my phone and tried to get a pic behind the head (it's tight back there) and it looks wet. Can't tell if it's just the copper washers leaking or if it's the line itself. So far its a small leak, just a drip.
Could this cause a slight hard start issue? I noticed yesterday morning she seemed to start a bit harder than normal. (Temp was low/mid 40's)
Thinking of just replacing the line, banjo and washers also whatever seals at the "T" as well.
Any thoughts?
See pics, best I could do in that small space.
