Is there a foolproof way to tell if I need a heater treater?
- Replies 27
- Views 8.1k
Doubletrouble 12 posts
Mopar1973Man 6 posts
Tractorman 4 posts
Royal Squire 2 posts
For the second generation Dodge Ram ('95-'02), this is about the blend door actuator. It is the only electronically operated ventilation door on our trucks. The rest of the doors are vacuum operated
Typically when the plastic coupler breaks then the motor just keeps turning and never stops. The last one I went to service it would turn both ways and never stop but the air temp will not change from
Like the title says, is there a foolproof way to tell if I need a heater treaters? I looked at the blend door motor yesterday, it does move when the temp knob is turned but I can't really tell if the door is moving at the same rate. Am I going to have to take the motor off and remove the little piece just to see if it's cracked?
I'm asking because I like some others on here have heat, it's just not as hot as it should be at the vent.
A year or so ago I replaced the heater core and a/c coil and inspected the door seals. That should all be good. Seals were in good shape and everything seemed fine. Since then (and before) I just don't get piping hot air coming out of the vents even with the engine twmp gauge reading 190°. So I figure it's time to check the little plastic thingy in the blend door.
Any thoughts?
Wish I had a laser thermometer to check heater hose Temps. I know one gets pretty darn hot, can't hold onto it. The other is slightly cooler. You can hold onto that one.
