Client wanting me to look at a oil leak.
- Replies 17
- Views 2.5k
Mopar1973Man 7 posts
Doubletrouble 5 posts
01_Cummins_4x4 2 posts
LorenS 2 posts
Yes the truck is worth it but I'm sure the engine is going to be pulled and replaced. The owner said he has a source for a new engine. As for the cost I'm not totally sure as of yet but we will see.
If you buy the engine you have to guarantee it. If he buys it and something isn't right you are off the hook .
PITA. Last one I pulled out its was f-ing tight. The worse part is get all the radiator and intercooler out and then even with all that out squeeze the oil pan up over the frame and not slam the rocke
https://www.tiktok.com/t/ZTRQdt1Uv/
Client called and asked me to come out and look at a oil leak on 2006 Dodge Cummins. When I open the hood I knew already.
Over 200k on the injectors and most likely wiped out number 6 piston. Watch the TikTok.
