Anyone try these lights?
- Replies 15
- Views 3.7k
Doubletrouble 4 posts
Max Tune 2 posts
LorenS 2 posts
Hutch24v 2 posts
I think most of the wiring is there, but IIRC there's like a "jumper" from the main harness to the lights. I was going to look at that this afternoon, and instead discovered that a squirrel had again
I got a set of them off Amazon a few years ago. They work OK. Because they are LEDs, I have both lights on full time as DRLs using my lift pump relay. I like the fact that they are DOT approved. I w
Yet they have cooling Finns on the back.....go figure 🤔 🙄 😒
Just curious if anyone has tried these. They're similar in appearance and design to the Harley Davidson day maker headlight. I have one on my bike and it's very bright.
I would not be powering these through the factory headlight switch, rather use one of the switches in my switch panel.
They also have the halo if you want to hook that up. May just power both the halo and light on dame switch. Not sure yet. Haven't ordered them yet, still debating.
