Dreaded No Bus and everything that goes with it
- Replies 22
- Views 15.8k
Piston 9 posts
Mopar1973Man 7 posts
01_Cummins_4x4 2 posts
Doubletrouble 1 post
I just did the PCM grounds on my truck a few weeks ago as i was having an issue with my torque converter not unlocking when letting off the gas pedal. I will tell you when I finished and got in the t
The gas truck wiring will be different than your diesel wiring harness. You really need to install your original complete harness and related electrical components from your original cab first, and us
Keep us posted and we will continue to get you on the right track.
Hi Folks. I am looking for some direction with my no bus issue. I did a cab swap on my 02 2500 4x4 24 valve automatic trans. I just bought the truck and did notice the fuel gauge was acting up before hand but didnt notice anything else but then again I bought it as a project and got right to work. After I got it back together, I would get a few gauges acting up and every 3rd or 4th keystart, I would get a no bus message. Here is what I have now pretty much with every keystart - No Bus message, Alternator not charging, None of the gauges are working, Starts off in 2nd gear - Limp Mode?, no communication with code readers, O/D off selector not working, dash warning lights on, codes 920, 921, 999 on the odometer. I checked the voltage on the #3 and #11 pins of the OBD connector and have 2.44 on pin 11 and 2.45 on pin 3. I understand this is a communication error between modules and could also be an issue with the cluster as well but would like to know where to go from here.
Any advice or direction would be greatly appreciated!
Thanks!
