- Replies 9
- Views 2k
Doubletrouble 3 posts
Tractorman 2 posts
W-T 1 post
Max Tune 1 post
Popular Days
Yeah...me too, I was under the passenger side the other day and I found a spot of dirt so I freaked out, ran to get some Q-tips and a tooth brush to fix it! Boy, am I glad I found that, I would h
W-T believes that only two things need to be in a shop. You've seen one (his truck) - the other...., - John
Geez @W-T your truck looks better from the underside than mine does from the topside
I'm asked frequently why I consistently "tinker" with my truck even though it's running good, no maintenance issues to address usually, just want to flip the hood and stare in amazement sometimes.
But, this time I spotted something while I was installing a BHAF this morning.
The lower exhaust manifold bolt on the rear cylinder was backing out!
I grabbed the tools and tightened her up and checked the rest. The upper bolt on the rear cylinder was about half a turn loose as well. All the others were fine.
Glad I caught that!
