24V NV5600 “runaway” please help!
- Replies 9
- Views 2.5k
harryslemons 3 posts
JAG1 2 posts
Doubletrouble 2 posts
Mopar1973Man 1 post
Popular Days
I would also proceed with the instructions of @JAG1 in checking for an oil leak into the turbo piping. Any extra oil/fuel will cause it to Rev uncontrolled. Eventually it could get to the point of ser
A/C ripple is damaging to the electronic circuit boards, PCM, ECM, ECU and can cause fluctuations in some cases. Both my second gens seemed to run smoother, noticeable even when running at idle. Befor
It us beneficial to automatics having shifting and lockup issues. It also benefits manual trucks by eliminating the a/c noise from the equation and also fixes the horrible ground wire splices u
Hey guys so this pretty much all happened about a year ago, I was cruising home ( nothing crazy) when all of the sudden the truck started surging and gaining MPH/RPM. Limped it home it would just randomly spike RPM to redline sporadically and come down to idle. changed fuel filter and seperator (FASS) and found my FASS had a popped fuse, fixed that. 16 PSI of fuel pressure, no CEL and issue still occured. Put a scan tool on it and the scope showed spike in voltage on ECM, APPS, and VP while the RPM jump was happening. Im leaning towards replacing the ECM. The truck has been off the road for nearly a year now from this and really want to get it back running. Has anyone run into an issue like this???
