- Replies 15
- Views 5.7k
JAG1 5 posts
2ndGen2002 4 posts
Mopar1973Man 3 posts
Tractorman 1 post
Keep the stock filter. You'll increase the filters ability to remove debris. I've got 3um filter on the AirDog and 7um filter in the stock filter.
Personally I would not return any fuel to near the straw your just adding hot fuel near the straw and foam to the fuel being drawn up. This will degrade the pump performance and increase fuel temps be
Whatever you do, don't drill another hole. Just stay with the one you drilled. My draw straw is installed to both my trucks thru the tank lid somewhere thru that but, I cannot remember the exact locat
Hello, im currently installing my draw straw and i cut a hole in the tank where i thought it would fit, but it turns out the fittings don't have room to clear when the housing is pushed down all the way. How would i remedy this? should i put a 45 degree fitting on one side? or maybe cut another hole somewhere on the tank and somehow fix the hole i cut already? interested where everyone else has put there straws. Thx im in a bit of a pinch right now so all help is appreciated.
