MAP sensor again or so I thought
- Replies 5
- Views 2.6k
wil440 2 posts
Mopar1973Man 1 post
Evan 1 post
hdpwipmonkey 1 post
I had a bad MAP maybe 2 or 3 months ago so ordered a SMP MAP from Rock along side the long steering joint, long story short, the steering joint bashed a hole in the box and on arrival no MAP, it had simply fallen out somewhere in the well over 3kmiles to get to me, to be fair Rock sent a replacement straight away, actually within the very same day as the delivery day, cured the no boost problem no bother
Fast forward 2 or 3 months and the same deal, intermittant no boost then everything all good for a indetermined time then no boost and NO power
I have been running my quad on LVL1 stock with boost fooling due to the damn cost of fuel here in the uk, ordered a new MAP 2 days ago with a view to a warranty claim with rock later now here comes the head scratcher, I thought " OK I'll try the quad on a higher setting" set it to LVL 4 and up to now no boost codes, check engine or no power...... WTF I cannot see how a higher setting on the quad gets rid of a MAP sensor fault, to be fair I haven't checked voltages or continuity yet
