- Replies 16
- Views 2.4k
Mopar1973Man 5 posts
IBMobile 3 posts
LD-Ordie 3 posts
Doubletrouble 2 posts
Popular Days
Below is paraphrased from the official CA smog check handbook. Inspections vary from state to state. Open the hood and do a visual Inspection. To pass inspection, the required emission
I just had to smog my truck last month, lady ran a mirror under the truck but never popped the hood. Just stabbed the OBD2 port and the sensor in the stack. I put the quadzilla on level 0 and passed
40 warm up cycles. So you have to start with a cold engine and warm up fully for 40 cycles without tripping the code again. Much easier to clear the codes and drive the truck to check for new codes an
On my 99 3500, I have a smog check due. I have a Smarty which I just put back to the stock mode. How long or how many mile are required before the history is removed. Is there a way I can check it before I take it to get it smoged? I have a normal reader and the Smarty. Thanks
