New to Auto Transmissions
I have always had a manual on all of my 2nd gen cummins trucks, mainly due to the obvious reason's we all know with dodge transmissions, to include failure, reliability, strength, and PRICE (auto), especially when you add any power to it.
So now I am trying to do a crash course on auto transmission in 2nd gens cause I am clueless on everything/anything with them. Man this is making me feel so dumb... withstupid
Gonna be trying to learn about lockup, torque converter stall, billet this and billet that, what auto parts, auto computers or tuners?, etc...
I am so so so tempted to put a nv4500 in this build, just for the availability and strength! Please reference 24v 1500 Cummins Thread check it out in the cummins swap section)
1999 Ram 1500 Shortbed 2wd Cummins Inspiration Video of what I'm going for
But I think Ill regret it in the end since this will be a play truck obviously. (Keep in mind I plan to try and keep power around or below 600hp) Ill just be spinning the tires irregardless in this light truck... NO - 4wd
I have rebuilt my NV5600 before (for my truck in sig) but I think rebuilding an auto would be way out of my league even with my extensive mechanic background with JD.
So Ill list just a few questions/thoughts to start with for the well versed auto guys.
1- Should I still go for an auto over a simple nv4500?
2- Could I rebuild an auto? (this could expand into another big discussion via what parts/brand etc.)
3- Who/where would you choose to send a core to and have them rebuild it for you? $$Suncoast - ATS$ Transmission - ETC
Edited by Stanley
  • Replies 30
  • Views 3.5k
    Think about your purpose mostly. What is the plan for the truck and what will it be used for the most? Then build this truck for that purpose and enjoy the craft you made! I totally understand why so
  • Ill jump in here after just recently buying a nv4500 truck but after putting almost 300k on my 02 with 47re ive had for 20 years My 47re was refreshed ounce by a mechanic. That lasted till the cheap
    Never actually. Never had 5th gear nut issue. I broke mainshafts twice and destroyed 5th gear and 3rd gear. Never 5th gear nut.
PCM that has the proper software for automatic Cummins. Basically you need the entire under hood wiring harness. This should have the transmission connectors. Make sure the ECM is ready for that PCM so it might be worth sending the two off to Auto Computer Specialist and let them flash them both. I've done one auto to manual swap which was easy.
Personal Note. Sorry for being MIA I've been working hard here in the yard trying to get everything clean up after the landslide.
Little update:
Luckily! I found a 2000 running 2wd cummins truck for 2k. Gonna part out but keep engine and trans. Ill post on my main thread some other details I'm getting out of this deal.
So I'm gonna use all the wiring from this truck since it had an auto and lots of upgraded options I didn't have initially - posted in main build thread.
Ill have wiring, pcm, ecu at my disposal, wiring is coming out, I just got the transmission pulled yesterday.
Couple of things:
I want to get rid of heat exchanger
I want to have a stand alone cooler system- new lines- new cooler and fan. I've seen some setups just doing a quick google search but I am unsure of what I need exactly. Do you simply just mount the cooler and fan on frame (under bed in front of wheel as Ive seen) then route new lines straight to the transmission? Or route new lines to a new cooler in original location. Keep in mind this just a play truck with no towing.
*Ill also need to figure out/learn if Ill need the "ant eater trans controller" from fire punk
*Trans purchase is still up for debate from Firepunk or Randy's
Check out my main build thread for more updates and well... Questions.
  • 3 weeks later...
I dig up the stand alone control you need to shift a eltronic 47.
This is a badass project
You dont need the computer and all that.
You did a 5600 so the 47 will be easy peasy. I just did my nv4500 and found i preferd building the 47
Throw gpz clutches in it with a few extra per kit. Do all billett upgrades you can afford aply pistons ect.
Upgrade imput shaft with a good valve body.
2 grand goes along ways building a 47 even
Spend most your money on the the tourge convertor.
47 will a decent build holds 600 easy 5th gear wont fall off and just plain is way more fun to drive.
Youl stay on boost chirpn through the gears going sideways down the street.
I just spent 2000 grand on my 4500 for virtually little to no gain just replaced all the broken stuff. For the same not broken stuff. Its kinda sad actually.
https://shop.firepunk.com/products/firepunk_engineering_anteater
Edited by Evan
Idk if I'd attempt a full auto trans rebuild. The nv5600 wasn't extremely hard just tedious. Im looking at 9k eitherway I choose firepunk or randys. Only difference is randys is for 650 hp and firepunk is at 850 hp. Don't know which is better still only the fact that Ill have a really nice buffer zone for hp goals for FP rated at 850, cause I'll never hit that with this build unless I spray.
Still not overly sure I have to have the ant eater, it would make "trans tunes" a cake walk.
Still lots of questions about ecu and pcm though.
Haven't had anyone suggest any helpful tips or answers to those yet....?
ATF <-> Coolant cooler you can ditch if you have enough to keep your transmission temperature under control.
ECM and PCM will need to be flashed to match what you are putting together.
@Mopar1973Man
Will the 00' pcm work with the 02' ecu if the 02' ecu of flashed to be (auto) instead of its original (manual)?
*I need/want to keep electronic cruise control.
2nd option- if not*
Can the 00' pcm be updated to work with the flashed 02' ecu (auto) ?
Absolute worst case*, I still have them 00' ecu. Then it will all be 00' electronics, ecu, pcm etc. And if need be, hopefully they can still add the 3 cyl hugh idle and 6 cyl high idle. Ill just have to either live without cc or try and mess with the parts left over to make it work. Just to note the engine will still be the 02' HO but with a SO pump.
*I guess another curious question is:
What all can auto computer specialists actually program with ecu and pcm for our trucks?
Basically in a quick nut shell.
  • Engine and Transmission harness.
  • ECM Flashed to Auotmatic software.
  • PCM Flashed to Automatic software
You need these things and to have the wiring for the transmission. The ECM needs software changed and PCM being the PCM controls the transmission shift.
