  1. Tap the 3-dot menu (â‹®) in the top-right corner of the browser.
EPA or CARB certified tuner
What is a good EPA or CARB certified tuner? Utah has changed some laws and the Adrenaline is no longer legal in my county.🤬
How are the Smarty tuners? Do they have any timing adjustment capabilities?
Any experience with Edge Juice w/Attitude?
Any suggestions are appreciated.
Also, wasn't there somewhere to sell items on here? Anybody looking for an Adrenaline w/IQuad?
Edited by Zamboni
  • Replies 9
  • Views 1.5k
  • Zamboni
    Zamboni
    I have an old economy tune you had posted on here back in 2020ish. I have made a few tweaks over the years but I have been running it sine 2021 and it serves me well and doesn't smoke, that is why I t
  • IBMobile
    IBMobile
    That's what I do with my Edge EZ every 2 years for the CA Smog Inspection. It takes 5-10 minuets. When I bought the EZ it was legal here and no inspections were required. Then every Ram diesel pic
  • Zamboni
    Zamboni
    This exactly. I chose to dispute the violation for this reason. With the price of fuel I am not going to give up 20 MPG. The letter they sent me had a clause for engine not being to operating temp.
What???
I have lots of questions to how this is even an issue and who would even know?
Are you just trying to pass an inspection?
Someone better tell Diesel Auto Power! burnout
No. Basically just 1 to 5 levels but no custom timing. Unless your pockets are super deep for about $2000 you can buy Smarty Touch but its still only a 60 HP tuner.
I left them because of lack of timing and custom timing adjustments.
Doesn't exist, really. Anything that modifies fuel or timing is NOT EPA or CARB certified; basically, anything that can change the stock tune is illegal. Tuners of any type, larger injectors are modifying the fuel flow amounts. Basically, we all deal with keeping our truck running clean and tuned.
I would take some time and relocate all the tuner module under the dash. What they cannot see can't be illegal. The biggest thing is making sure your tune does not smoke! There is a way of making completely clean tunes. I wouldn't give up your tuner. Another idea is to remove all of it, do the inspection, and hook it all back up.
Good idea on hiding the tuner. I believe that can be done and will be the way forward. Right now I am disputing the ruling since the county told me the tuner has always been illegal and they (the county) performed my emissions test for the past 12 years with nothing ever said about the tuner in plain site under the hood.
As far as smoke, I have none. My tune is spot on and getting 20MPG not towing. I do have 100hp injectors but I also have a 62/64 DAP stage 2 towing turbo which cleans up any excess fuel without smoke.
FYI most EDGE tuners are CARB compliant since the tunes are set and non adjustable.
Thank you for your input. I am hesitant to change tuners because of the lack of timing adjustment.
20 hours ago, Stanley said:
What???
Some one turned me in to the county for excessive emissions from the tail pipe. I call BS since I know better, I think they were mad their BMW wouldn't keep up.
Umm. This is why I love the Quadzilla Tuner: you can control smoke and produce a clean tune. Just most people over-tune (excessive fuel & timing). There is a way to get the most out of the tuner, but you have to think about what you are setting up and your driving style. Fuel should not be above 100% till you need to pass someone, and you should not need added fuel to drive on a normal highway. In other words, build a tune that you can normally drive at 100% fuel till say 15 PSI of boost, then ramp up above 100%. As for timing, yeah, you can go anywhere but... Retarding helps with launching and building boost, so make sure your 1500 RPM band is low, say 12 or 13 degrees. Excessive timing will prevent boost building, and yeah, creates smoke when you roll into the throttle, it should RETARD to spool.
If you want stupid power build that a totally different tune you use in private. 😉
Yeah one reason I dumped Edge long ago...
I have an old economy tune you had posted on here back in 2020ish. I have made a few tweaks over the years but I have been running it sine 2021 and it serves me well and doesn't smoke, that is why I think the claim is BS. I also use one of your old tow tunes that I have tweaked a little. works great for 12k lbs.
Thank you for the advice, this site helped me tremendously in the past and I still peak once in a while.
When I bought the EZ it was legal here and no inspections were required. Then every Ram diesel pickup truck 1998.5 and up was to be inspected and the Edge EZ became a noncompliant device. Ah, states laws, one day your good to go and the next day you're felon.
Thank you @IBMobile for posting that! I'll never remove my tuner for no laws.
Sorry, I've had enough of BS policies that have no basis. When a person actually tunes an engine and makes it more efficient, why would you give up your tuner? Like myself, my best so far to date was from Seattle WA, to the Idaho state Line outside of Lewiston Idaho and travelled 300 miles across Washington State and only used a 1/4 tank of fuel. Remember, the government hates it when we make our diesels more efficient because the Government doesn't get the tax dollars from fuel (highway fuel). If you're running more efficiently, then you're polluting less, too!
The letter they sent me had a clause for engine not being to operating temp. My commute is less than 2 miles each direction, my truck never gets to temp unless it's cold out and I warm it up. I will get it to temp and they are going to put it on the dyno test and check it out. Then I have a meeting with the Environmental Health Scientist. He is like 25 years old, I have been a mechanic longer than he has been alive. Wish me luck.🤣
Ditch the Quadzilla and let him look it all over. Then, when he's done, put the Quadzilla all back in.
