Torque specs
My clutch of 7 years decided to peace out today (throw out is just screaming). 1 month short of my trans rebuild slated for end of June (of course). I bought a Valair DD quiet clutch kit 2 weeks ago and I have South Bend hydros already (clutch is a single disc SB)
I need to pull my bellhousing adapter plate off to reseal my rear cam plug. Does anyone know the torque spec for the bolts that mount it to the back of the block?
Because it’s DC I can’t simply log into QSOL and find it by ESN.
Gonna do my rear main seal too (sleeved style). I found a NOS Cummins installer for that particular seal for cheap online so I know have just about every tool for the 24V one can think of :)
Edited by Mace
  • Replies 12
  • Views 1.3k
  • Tractorman
    Tractorman
    I think this is what your are looking for. Removal (9) Remove the eight flywheel housing to block bolts and remove housing and starter motor as an assembly. Installation (9) Install the flywheel
  • I used the Valair QNV56DDSN-ORG clutch. Much much quieter then a SBC DD 3250 I ran years ago. It 's enjoyable to drive. Yes, I installed it. It went together perfectly first go.
  • Mine were all raised exceptionally poor chamfers on all holes leading to threads surface was raised. I had to fix it before bolting clutch to it. I sent a email to valair with no response. Was just t
Removal
assembly.
Installation
(9) Install the flywheel housing and bolts. Tighten
the bolts to 60 N·m (44 ft. lbs.) torque.
  • John
  • 4 months later...
Did you do this clutch install? How where the chamferd holes for the pressure plate to bolt to.
On 10/21/2026 at 3:20 PM, Mopar1973Man said:
Sorry I've been hung up working on many other things.
@Mace what clutch did you get?
Was just the hd 13" organic. Was first and last valair purchase
Beast and Thor are bottom doing fine or the Valair dual disc clutches. Thor has the better clutch with the springs on the center disc to keep the chatter down.
I thought you were calling the dual mass flywheel better for a second.
Hows the hopping getting going.
My organic 13" hd hops about like stock clutch. Was thinking about trying south bend. I have no faith in the valair or even if its the clutch as .
advertised. No valair markings anywhere on clutch or flywheel. Only thing i do know is it meausures 13"
I would much rather a 47re so maybe its just me. These manuals suck to trive 4500 5600 and g56 all suck
Curious what about them? I want to understand what part of it that sucks?
The part where you let of throttle grab stick and row it into a gear. ;)
Dude that's a normal manual. Unless you can float different deal.
