- Replies 20
- Views 5.7k
AH64ID 6 posts
dorkweed 5 posts
ISX 3 posts
CumminsinKansas 3 posts
Our service truck is a 2007 CR automatic and there are several issues I am wondering if anyone else has ran into. It has 150k. Completely stock.First is the windshield wipers. When on the slowest setting, they will wipe one, then again with time in between like normal, then it will wipe twice without stopping, then it will act normal for 3 wipes or so, then it will wipe 3 times in a row or 2 in a row. Not sure what the issue is with that.The ignition now thinks the key is still in it when you take the key out as all the dings are still going along with whatever light stays on, on the instrument panel when the key is in the ignition. It takes a long time to start, like 2 full seconds. Is that normal? Sometimes it takes 3 seconds. Just curious on all this, not really an issue of mine but I am wondering why it does all those things.
