- Replies 27
- Views 12k
flagmanruss 6 posts
Mopar1973Man 4 posts
JOHNFAK 4 posts
Heavyd1980 3 posts
I want to install the BHAF further onto the fender than typical. I like this heat slick heat shield. Furnace duct heat shield: http://www.directcon.net/drkayak/Ram/Heat%20Shield But further onto the fender. But then the OEM flexi intake tube will be too short & angled wrong. I found rubber eblows... but that would require 4 more clamps & 2 metal or plastic tubing pieces. I was wanting a clean install. Rubber elbows in all sizes: http://store.airflo.com/nextpage.html Nice Custom Metal extension elbow: http://www.cumminsforum.com/forum/98-5-02-performance-parts-discussion/143145-bhaf-7.html but is not something I could do myself. http://www.amazon.com/Spectre-9798-Degree-Polished-Aluminum/dp/B001OMK4R2/ref=wl_it_dp_o?ie=UTF8&coliid=I2AHHC3DE5ITYS&colid=1QKBZCL48WMAO Well, I guess I can manage a couple of hose clamps. LOL! A Spectre part. A mandrel bent piece of tubing would be delightful, if it would fit... but I don't see any in my price range. Or does one just hit the local plumbing supply? I have found additional sources. Summit Racing offers some Spectre intake parts... I found even more Spectre items on Amazon. This is going to take some careful test fitting, measuring & by guess & by gosh, but I'm closer. Your thoughts are appreciated. Russ
