My new Exhaust: Diamond Eye Performance 5" TBE
- Replies 36
- Views 11.3k
Rogan 13 posts
Prowelder 7 posts
Heavyd1980 6 posts
SEJohnson 4 posts
Just a quick post about my new exhaust. I had only a stock downpipe and a short piece, cut off right before the OE muffler, coupled with a turn-down. That was it..So I got a Diamond Eye Galv. Steel 5" turbo-back exhaust from my buddy Jeremy @ Disturbed Diesel.Removal of the stock downpipe was a little rugged, with my (5) 6-inch extensions put together, a 13mm socket, ratchet, PB Blaster, and JB-80.PBB wouldn't do squat, so I shot it with JB-80 and out the two bolts came.
As you can see, the new DP is 3" bell to 4" downpipe, to 5" adapter, then 5" the rest of the way. In the above picture, there's a 40" x 5" piece of tube not shown. This piece would later prove to need cut down to around 19", and used pre-muffler.Took me a few hours to install, laying on my back, 30-35*F and breezy, in the driveway. The directions were as generic as you can get, so it took some thought process, and a little creativity to get it all mounted, and use as many factory hanger positions as possible.I ultimately located pieces as such:DP > Adptr > 40" section > muffler > 19" section(cut earlier) > over-axle > Tail section (end needs shortened, as it'll clear a DRW application, as well.)I actually ended up welding the adapter to the 40" section to eliminate the need for that clamp.I ended it it all with a 6" SS tip, just to 'dress' it up a touch. Even if it's like putting lipstick on a hog.. :cookoo:Results: I can HEAR again!! I can hear the engine over the exhaust, whereas I've not been able to do so, prior. And I get to turn the radio down now :)And the turbo whistle is very pronounced. As for the exhaust note, it's a lot deeper tone, and sounds pretty good, actually. Once the muffler gets a few hot-cycles on it, I'll let you know how it sounds then, as I assume it'll get a touch louder, and better tone to it. We'll see, though.
