- Replies 40
- Views 11.6k
Mopar1973Man 12 posts
groundHog 7 posts
LiveOak 5 posts
flagmanruss 3 posts
New to this forum and need some assistance. Recently purchased 02 3500 truck with 188k miles on it. My understanding is the fuel pump should be changed out and relocated due to the heat from the engine. The truck runs fine, but don't won't to screw up the injector pump. What pumps are recommended for this fix and where do you get the best bang for the buck? What are the pros and cons of the kit from Dodge, other than it is too damn expensive? Has anyone had any luck at repairing the rear plastic fender wells with the types of epoxies on the market? Duramix? Automix? What about adding a fuel pressure gauge and where should it located? Thanks from Texas.
