Heat Shield for the BHAF
I have had a few people ask what my heat sheilds look like so here's mine. Nothing fancy and it needs paint.
  • Replies 52
  • Views 18.6k
  • It was before his beak grew out.
  • I knew when I typed my response it could be taken in more ways than one, but the more I typed the more I could not resist. Here's to being 7 seven years old again, boys and girls.    No offe
  • A little younger than 7 but I long for the days of life so simple.
Just now, Mopar1973Man said:
In stock form without any injectors, tuners or fuel mods I was able to measure 1,400*F EGT's towing up a 7% grade. It was just a Chey 3/4 ton pickup on the trailer. Cruise set for 60 MPH.  When I noticed the temp I backed out and dropped a gear and kicked the RPM's up and it settled at 1,200*F the rest of the way.
So is that measuring the temp in inside the housing or outside?  I guess what would be good to know is if the temp of the actual housing there or the air inside of it.  I have a pyrometer for tires perhaps I can measure the turbo housing when it's all nice and hot.  Not sure how high it goes I'll have to see about that.
Pyrometer typically is measuring the flame temperature inside. You could use a normal outdoor thermometer and measure the temperature around the BHAF. I know ISX did this long time again and typically without a heat shield, the temp was much more than +10*F over outside temp while rolling. Bein this is old information it might be worth testing again and seeing what you get for measurements as well.
This is the one I have.  I think it goes up to 199 degrees but it doesn't say weather or not that's F or C so I sent them a inquiry to find out.
https://www.joesracing.com/i-21092094-joes-deluxe-racing-pyrometer.html
I'll look into measuring it somehow.  I like to measure stuff LOL
Edited by leety
Just now, dripley said:
The description says it measures in C and F.
Correct, it does, I'm just not sure if the limit is in C or F based on the.
In the 4th detail tab the info is as follows:
DETAIL
OVERLOAD DISPLAY
The digital display will indicate 1 when the input exceeds the measurement range selected. A damaged probe will indicate 1 on the display.
If measuring above 199.9°  <<<<-----NOT SURE IF THIS IS F or C???
I made my heat shield setup from heat shield material used between the catalytic converter and car underside of MBZ I found in the salvage yard .  Cut it with a cutting wheel on an angle grinder, bent and screwed in to shape.  I drilled and mounted it to the studs that hold the air box in.IMG_5131.JPG.f2f33bb0a7a33f3ae2ccf797eb60c323.JPG
Cool!  I think I saw that pix earlier while looking around here but I could never get back to it.  I was wondering what the build was on that.  Is that the stock air intake tube?  I have a K & N that's too long and I can't cut it becuase I have to put the K&N Costume back on to pass smog later :-) so I have to leave all those parts in tact so I can do the quick costume swap when smog time comes again.  California requires some trickery sometimes.
DETAIL
OVERLOAD DISPLAY
Ahh, I see. I just gave a quick look and saw the C and F. It says alot about measuring tire temp. I wonder how well it reads air temp?
 Speaking for @IBMobile and myself, that is the stock intake tube. I have the same set up only without the heat sheild. Mine is not as pretty as the brand new.post-338-0-88651000-1441636017_thumb.jpg
I like that support widgit good idea.
It keeps it off the oe box bolts. You can do the same with a heat shield.
Looks like someone is due for filter change getting rather dirty looking...
Yeah it has been in there for near three years. The white does not last long on mine. Hooked it up to good size shop vac a couple weeks ago to see if I could blow anything out of it and it still free flowed what ever air the vac was putting out. Like it was not on there. Still about time for another. The engine pulls a little more air than that vac puts out. Sarcasm intended.
  • 4 weeks later...
I have a first draft of this idea in place.  I'll probably redo it at some point this is a good start point for an experiment.  So far so good.
Any and all comments and/or suggestions on ways to improve this are more than welcome.
I need to swap out the bottom plate with a better piece.  This was just some stuff had around that I folded in half and taped up around the end for the test run.  If I use a larger trash can and make it taller I can but a rubber seal on the top of it.  I may use a larger trash can next time.  The fun thing about this fire resistant trash can is it won't light on fire with an open flame or react at all.  No blistering or any of that.  Just carbon from the flame built up on it an that just came right off with a paper towel.
Edited by leety
Looks great Leety!!!!!
I like that idea!
The fire resistant can plus aluminum heat shield on it and I would say you're good to go.
My sled has aluminum heat tape on the inside of the belly pan by the exhuast and that keeps it from melting.
I installed my BHAF wednesday. I just put it in and didn't worry about a heat shield yet.
A little note.
The mounting fasteners off the stock air box make great mounting points for the filter.
Ripped the box out (literally). Sawzalled the pucks off the bottom of the airbox. Put those and the inside part over the fender screws. Ta da.
I like that idea!
A little note.
Yea the stock air box was not in the truck when I got it.  I have a little rubber cap over an acorn nut on the nut closest to the battery.  The's already a small dent in the metal cage.  I'll have to do something about that soon.  Probably just an aluminum strap to cover the nut or something like that.  There needs to be more surface area on that contact point for sure.  The bottom plate will at some point be replaced with a thicker piece of aluminum as well, that gorilla tape is annoying me.
I agree Leety.
The stock studs are no go for resting the filter on.
The original air box grommets were just a touch bigger than the metal on the outside of the filter.
On my old truck when I ran an Amsoil filter for a bit I made a filter frame out of aluminum stock like @dripleydid.
Edited by Ben
1 minute ago, Ben said:
I agree Leety.
No doubt that's gonna happen soon. I have the strip of aluminum waiting.  I just have to get to fabbing it and having a nice spot for the filter to rest.  That's on the short list.
I want to see your widget, in the most polite way you can show it.
Dude....
