5 OBDII Error Codes! Won't start. Thoughts?
- Replies 26
- Views 12k
Mopar1973Man 5 posts
dripley 5 posts
airborne66 5 posts
JimRAM 3 posts
My 1998 Dodge RAM 2500 Truck just stopped dead in the street and won't even try and start. IT has a 5.9 L inline 6 cylinder, 24 valve Cummins diesel engine. I hooked up an OBD II and got the following error codes listed below. The forum here has testing procedures but the first requires the engine be running (it won't start) and the other require a DRBIII scan tool (expensive). I'm just trying to get this running again without major expense. Any suggestions on where to start without the DRBIII? I can check wiring as indicated. Do the combined codes point to a specific item that needs replacing (the fuel injection pump?) with certainty? One thing I looked as said erasing the codes with the OBDII may allow it to start and run. I'm hesitant to do this since it appears some onter information may need to be read by the DRBIII if I have to take this to a shop. Any thoughts or recommendations??P0121 - Accelerator Position Sensor Volts Do Not Agree With Idle Validation Signal P0234 - Turbo Boost Limit Exceeded. Problem detected in turbocharger wastegate. P0253 - Fuel Injection Pump Fuel Valve Open Circuit. Problem sensed with fuel circuit internal to fuel injection pump. P1688 - Internal Fuel Injection Pump Controller Failure. Internal problem within the fuel injection pump. Low power, engine derated, or engine stops.P1689 - No Communication Between ECM and Injection Pump Module. Data link circuit failure between ECM and fuel injection pump. Low power, engine derated, or engine stops.Thanks! JimRAM
