Steering wheel loose & making popping noise?
- Replies 15
- Views 6.3k
Mopar1973Man 5 posts
Perrysburg Dodgeboy 3 posts
flagmanruss 1 post
cumminspower 1 post
Lately my steering wheel has developed some movement in it up & down & a popping noise. If you press on top or bottom of steering wheel it makes a pop & moves slightly up and down. It's even gotten so loose that the steering column & wheel seem to rattle when you hit a bump in the road. Is there anything common that gets worn out in these steering columns that causes the steering wheel to have movement in it like that & a popping sound. The popping sounds like it's coming in the area directly beind the steering wheel....Thanks for any help or suggestions.
