- Replies 18
- Views 4.4k
rth0006 7 posts
Mopar1973Man 4 posts
pepsi71ocean 4 posts
MnTom 1 post
Hey guys,I'm new on here but I have a question that I haven't been able to find a good answer for. When I first crank my truck it is hard to start whether hot or cold. When it does crank it idles fine. After driving maybe 5-10 miles and stopping at a red light the idle becomes real choppy. If I shut it off, it will fire up normally and idle just fine, but 5-10 miles down the road the same thing happens again. I have a fuel pressure gauge and for some reason when I was pulling a load it jumped around and then stuck maxed out. Every now and then it will jump around but I never get a normal reading like I did when I first put it on. I do not have a snubber or needle valve on it, so that is probably the problem as far as the gauge goes. Any suggestions? BTW, the injection and lift pump was replaced in march of 2010.Thanks for your time,Ryan
