I get this short high pitch squeal every time I shut the engine off. Sounds like a belt squeal but I`m not sure. neighbor said it could be a bad damper? What say you? Tx. 2001 dodge Ram, 5.9L 47re Trans.
  • Replies 7
  • Views 2.4k
Fairly normal, the motor stops faster than the belt can. I beleive there is a fix, but don't recall at the moment.. could be as simple as a new belt and/or tensioner.
got a new belt on mine. they just sneeze every so often. mine has done it for 10 years.
Put a new belt on mine too. Now, sometimes it does it, some time it doesn`t. Not much to be concerned about I suppose. (hope) Tx.
All that noise is is your shut down attentuator. After all, if it didn't do it how would you know if it stopped or not?:lmao:
you might be able to tell by the sudden sound of, whats that,.......................silence!:lmao2:
I believe you are correct. Wonder where I went wrong, I should have known THAT!. Lol. Tx for the reply.
