- Replies 11
- Views 2.8k
dripley 5 posts
EcoRI 4 posts
Mopar1973Man 1 post
gassernomore 1 post
Hi there, I've searched Google, this forum, Cummins forum, and TDR without luck - if this is a dumb or repeat question I apologize in advance!
The previous owner of my Dodge put the Autometer FP sender between the fuel filter and the line to the VP. The sender failed, I ordered a new one plus the snubber to prevent the premature wear on that part.
Problem: the FP sender is angled such that the back butts up against the drain valve and the snubber definitely will not fit. I'm pretty scared of messing up the VP and don't want to tinker around without the advice/recommendations from more experienced folks!
Can I rotate the sender/fitting so it doesn't stick out into the drain valve? Or is it fitting threaded such that this angle is necessary to achieve a tight seal?
Thanks in advance!!
-Tiffany
