10,000 mile oil filter?
Walmart has a Fram oil filter that says it is for synthetic oil and you change it at 10,000 miles. Anybody ever use it? That seems like a long time between oil changes to me. I bought it but I plan to change at 7000 miles. What say you?
  • Replies 12
  • Views 4.4k
Fram filters don't have the best reputation with a Cummins engine. Do a search for "oil filters" on this site and you will get all the info you would want to know about which is the best! Good luck!
Good idea, i`ll do the search. Tx.
Donaldson ELF7349 is a MUCH better filter (actually best avail) priced right and can go up to 25K miles if your inclined to run oil that long.
I live on the Ms. coast and haven`t heard of Donaldson. What store sells it?
Call your local Frieghtliner or Cummins Dealer, have engine# ready,don't tell them it's for a Dodge,Baldwin and Fleetguard are also good filters approved by Cummins.:spend:
Good idea, I`ll do it. Tx.
Tx The nearest store to me was 55 miles round trip so for this change I`ll stick with NAPA and Rotella 15/40 and check online for the next one. Tx again.
Look online as well, I hear of people getting them shipped for $12. I would try to run a Fleetguard Stratapore or Baldwin before a NAPA. If you do run NAPA be sure to get the XE version.
I`ll check the online suggestion, it works better for me. Tx.
avoid K&N and Fram filters like the plague.Use only Cummins approved filters on your motor, the exception are NAPA air filters 2790 or 6637.
