- Replies 5
- Views 3.8k
dobienut 1 post
dripley 1 post
anoldbiker 1 post
MarbleCrusher 1 post
I've been using Shell's Rotella Triple protection 15W40 for a while now for my truck and I also use it in my tractor. So today I noticed as I was changing my tractor oil that I needed more, went to buy a 20 litre pail and they had none. They had the 9.5 litre pail and i look on the back and it says the specs listed and it includes Cummins engines. I go to a different store, same looking oil container but the back doesn't say Cummins, but it's still a Heavy Duty engine oil able to be used in Heavy equipment same as the other container says. I call Shell when I get home and they say basically it's all the same oil, they just changed the look , took the diesel writing off of it so people realize it can be used for gas engines also. My hang up is are the lesser amount of specifications it can be used for on the back saying it's not good for Cummins I wonder? I know, I called the helpline, but I'm guessing it's a call center and I don't know if i really trust what a kid at a call center is telling me soemtimes when it comes to an expensive engine
