- Replies 18
- Views 2.7k
jamman 7 posts
Mopar1973Man 5 posts
dripley 3 posts
CSM 1 post
Hello everyone, I haven't been in here much lately, too much stuff. But now I have several things happening with the truck. Problem 1 I backed it up into the barn the other day during a downpour, so had to engage 4wd to not spin on the slope. I forgot to disengage as I moved and slid it out without enough time for it to fully do so. I parked it and left it for a few days. I start it up and bring it out and slide it out of 4x but I notice that my brake warning light never turned off, nor did my ABS dummy light. Now, my brakes were working, but the pedal travels a fair amount before I really find resistance. I'm not certain they are working at 100%. I've had a lot of brake dust on the front passenger side tire, just as extra info. It does seem to pull to the right. Problem 2 Seemingly unrelated, my front tires are really wearing funny. They are a more aggressive tread than pure road tires. I can't seem to find the words to describe the way they are waring, but it's not flat or even, it's different heights all over the tire. I should have taken a picture. There are pointed treads, like triangles pointed at the direction of travel. The points are higher, but further back is worn lower into the tire. Meanwhile, the rear tires are worn evenly across the width of the tire, very differently than the fronts. My thoughts: Problem 1-Seems like maybe my master cylinder may have up and died. So replace the master, do the front brake pads and look at my rotors. Problem 2 – Shocks shot? Replace the shocks. Should I also be doing ball joints at the same time? Never done either, but not afraid to tackle it. Just wondered if while I have it down I should be doing all of it. Seems like I had another thing but it's late and not remembering well. Thanks for any help or thoughts guys. Or, tell me what else I need to tell you to figure this out. jamman
