I need some help diagnosing my heat problem please
- Replies 29
- Views 7.3k
Mopar1973Man 7 posts
dually 4 posts
hawkeye213 4 posts
dripley 4 posts
When I turn my heat on it is just semi warm. I have searched the forum and checked everything. The Ac compressor kicks on and off correctly when the selector is turned. The air comes out of the appropriate vents when selected. The blend door works ( watched mopar video ) when the temp selector is turned. The big flapdoor over on the passenger side moves when the max AC is selected. The radiator was replaced and flushed 10,000 miles ago. New thermostat also. Temp gauge heats up to 190 and stays there no matter what I am doing. Both heater hoses going in from the engine side are the same temp and they are hot
. I pulled the glove box and can see and feel the heater core and the in and out pipes on it are both very very hot
. This heater use to get my truck unbelievably hot. I am inclined to believe its the heater core that is bad and I should just quit procrastinating and change it. Any thoughts would be appreciated.Thanks Rob
