it have to really shorten a story here. pulled my rv for the first time in a while. pulled it over the bluridge mountains at 22,700 total. notice on filllup that i had oil on the rv and the under carridge of the truck. check my oil and i have an extra quart in the crank case. figure i have a leaky injector or 2. been wanting some rv 275's for a while and ordered a set from DAP. GREAT PRICE AT $269 + $100 core. drove to my daughters house to install and sprung a coolant leak just before arriving. spent the day installing the rv's and then dealt with the coolant leak. from the best i could tell it was coming from the water pump. could not see it well enough to tell for sure, but it appeared to be streaming from the pulley on the water pump. got a new water pump and installed it. the leak was reduced but still there. every time i tightened the bolts a little more it got smaller. but i felt i was overtightening the bolts big time. it is late and i gave up on fixxing the leak tonight but wanted to drive the truck and see how the new injectors were working. so i put another gallon of water in her and took her for a spin. i mile out and one mile back. parked the truck and no water leak.temp is now at 180+, it has apparently stopped. and i cant make it leak now.have i missed something or do you have to drive the truck to seat the gasket? it was rubber and fit into a groove on the pump. does it take operation af the vehicle to seat this gasket?:shrug:
:shrug:
