You guys think my fuel pressure low???
my fuel PSI is 15 Idle 11-13 WOT..meaning on a hard pull it may pull to 11psi for 2-seconds if i get on the pedal hard like to pass something then it snaps to 13psi..I lost a 1-2lbs when i replaced my Fuel/Water seperator w/ the AirDog updated one, .."which is a Luber-Finer' FILTER and i was able to get the # for from "STANDARD LABATORIES" If any one wants it
  • Replies 25
  • Views 5k
my fuel PSI is 15 Idle 11-13 WOT..meaning on a hard pull it may pull to 11psi for 2-seconds if i get on the pedal hard like to pass something then it snaps to 13psi..I lost a 1-2lbs when i replaced my Fuel/Water seperator w/ the AirDog updated one, .."which is a Luber-Finer' FILTERand i was able to get the # for from "STANDARD LABATORIES" If any one wants it
You can adjust it up a little, your's is adjustable right? I the cooler weather I lost a 1/2-1 PSI. I may do the same on my Raptor.
Dave
from what i have learned here 14 to 15 is a good number for wot. mine is at 20 and 17 and i think i am going to turn it down a little when i get home.
The the winter cold coming on mine is slipping down again. :duh: Idle @ 18 and WOT @ 16... I know its the stupid check ball working its way into the spring again... :rolleyes:
I got the original AD100 - so 15psi and 11 WOT ...... spring is only way to adjustIm pretty sure mike said the return valve opens around 10psi - so makes sense over 10 is where to be ......
I got the original AD100 - so 15psi and 11 WOT ...... spring is only way to adjust Im pretty sure mike said the return valve opens around 10psi - so makes sense over 10 is where to be ......
Right from the Dodge Factory service Manual... http://articles.mopar1973man.com/index.php?option=com_content&view=article&id=88:bosch-vp44-injection-pump-overflow-valve&catid=25&Itemid=107
The valve opens at approximately 97 kPa (14 psi)
And...
Reduce regulated air pressure to 10 psi and observe valve. Valve should stay shut. If not, replace valve
Guys..my pressures are 15 idle and 13WOT...the lowest ive seen them drop was 11psi and that is only for a second and then it snaps back to 13+ instantly...
I think its where i dont have the draw straw, im using the 3/8 OEM fitting with the connector that came in the AD 100 KIT
MY PRESSURES before i installed the new F/W sep.filter was 16-17 idle and 14WOT..
Mike..if i can find the 17psi spring i orderd w/ the AD im going to try that in the next few days..
You might consider updating to the other spring. (17 PSI)
if the overflow on the vp opens at 14#psi and your pressure is lower i would say your are not getting all of the cooling for the electronics thats possible. could mean shorter vp life. i think i am keeping mine at or above 15 for that reason.
That may be some of your weeping problem too maybe. Whadoyathink? Dave
the pressure comming out of the vp to the injectors is in the neighbor hood of 4000#psi so i would not think 20# on the lift pump would cause the weeping.
Agreed!:)
It starts out at 4,500 PSI and can go as high as 20,000 PSI (or more). As for the weeping it most likely a bad sealing washer... :shrug:
As far as the pressure you have with the AD 100, that is normal,I had a 100 with the stock set up as your's and you are right on the money with the stock spring. Like Mike said get the 17 lbs spring and your go to go.
when you say sealing washer, is that part of the nut or is it a sperate washer?
It's a aluminum looking washer with a rubber washer built in.
i have seen those on several of the old fittings on the vp and the fuel canster buy never noticed any on the the nuts in the head.
i am talking about the nuts that attache the injector lines to head at the crossover tubes. not the ones rattling around in my head:lmao:
:lmao2::lmao::lol: If you jumped in on the last few posts only I'd have to wonder about you guys too!:nono:
  • 3 weeks later...
Guys is 20-21 at idle to high a fuel pressure??Thanks
